Animation possibility
Hello,
I don't ask questions a lot here but I found it necessary since it might save me some time.
I'm getting towards the stages where I start animating stuff for my project and I'm not quite experienced with animations hence my question:
The movement here is a bit complicated, maybe even too complex to animate in Onshape?
I did however try conceptualizing and maybe implementing using this example:
https://cad.onshape.com/documents/eb014ae849908dd1567b654c/w/ac8e8094f75706347ddea16d/e/ea97c3a384c30531e46e0a8e
But there are going to be a lot more moving parts in the future I plan on making that are going to have one big interconnected movement
If there are any other examples related to what I'm working with I'm happy to learn them.
Thanks in advance,
  • MichaelPascoeMichaelPascoe Member Posts: 2,341 PRO
    edited August 2024 Answer ✓
    It is much easier if you simply want to drag the chain manually. You can have a sketch with a single spline where each chain link is tangent to. Then you should be able to drag the chain along. But this will not really be able to animate. This way is easy to over-constrain and Onshape will throw a mate error.
    Maybe @john_mcclary can work his Rubix Cube magic and find a good solution for animating chains?
