How to add different size sketch fillets while in the fillet command.
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
edited August 2014 in Using Onshape
Here is a little trick to use the fillet tool while in a sketch to quickly add different sized fillets in one shot. If you add a fillet and try to add another one that will not resolve you will see this...
If you then click that corner point and drag it you will get this...
Now all together...
This lets you quickly add different sized fillets quickly. Hope that helps! ~Lou
