Help using sweep to design a marble run
nicholas_hammond089nicholas_hammond089 Member Posts: 5
I'm trying to use the sweep function to make a U shape go around a spiral. I drew the U shape at the bottom of the spiral and then used sweep and chose Helix 1 as the sweep path, but instead of climbing up the helix like i expected, it seems to have swept my sketch both forward and backward from the face of the drawing, instead of just in one direction. I don't see an option in my Sweep1 feature to change this. There is probably something simple I am missing if anyone can help
https://cad.onshape.com/documents/07cf5d1b5d4d58036bae8995/w/ae54e9d8a7894c1a29ce2dc9/e/d4b7a3bb09d80c7663c1a265?renderMode=0&uiState=67745998ebb0ef4f3457fb9f
