Imported model stuck to origin
gabriel_easlergabriel_easler Member Posts: 2
I'm trying to make a Coral intake model for FRC, and used the MKCad Deriver tool to import a model of the Coral piece. However, I cannot manipulate or move this piece at all, as it seems to be completely stuck to the origin of my document. I need to be able to move it around and get a good idea of where to put intake wheels/belts. Any solutions?
  • GWS50GWS50 Member Posts: 493 PRO
    can you share your document please?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Adding more stuff should be done in an Assembly, not the Part Studio where the part was imported. You can move stuff wherever you want.
  • martin_kopplowmartin_kopplow Member Posts: 1,150 PRO
    I'd always leave the imported part untouched as it is, then derive it into a Part Studio and work with the derived geometry there, like add features or remove portions of it, then assemble it in an assembly. That way, you can also easyly update the imported model without loosing your work.
