Simplify Geometry for URDF
sebastian_glanzner
sebastian_glanzner Member, Developers Posts: 498 PRO
edited February 2025 in Community Support
We are currently developing the 3D-printable robot "pib" and aim to streamline the generation of a URDF file.
Challenge:
Our primary challenge is obtaining simplified geometry that represents only the outer shell of each movable component. At present, we create new Part Studios and merge each part into one. Subsequently, we manually delete faces to eliminate internal surfaces and close gaps. This process is time-consuming and often results in errors.
We have also experimented with the "Simplify" custom feature, but our parts appear too complex for automatic simplification.
https://cad.onshape.com/documents/3f84343841cb6d7fead072c8
Current Project:
We have developed a prototype of a 3D-printable leg featuring a knee joint and a wheel as its foot.
Inquiry:
Does anyone have suggestions on how to achieve this simplification? Is there a FeatureScript available that can generate an outer hull?
Onshape Document:
pib - Humanoid Robot
