Help with Sketch
siddharth_shanmugam056siddharth_shanmugam056 Member Posts: 2
Good evening. I am currently designing a lantern face in CAD that I plan to laser cut. Behind my image silhouette, I have decorative triangles. I realized that each triangle is a bit too thick, and I would like to increase the gaps between them. How can I adjust this without breaking everything and having to start over? I’ve attached a few images of the sketch below.
Screenshot 2025-03-11 184749.png Screenshot 2025-03-11 184759.png Screenshot 2025-03-11 184812.png
  • MDesignMDesign Member Posts: 1,332 PRO
    erase everything and start over. Lol but do it in separate features instead of one big sketch.
    Don’t erase it all but rather use it for a guide. I’d suggest doing the triangle cutouts as a hole and then pattern that hole. Do the cat silhouette as a separate extrude cut and add a thin extrude to complete the silhouette. Makes it easier to tweak things later on.
  • ethan_pendergastethan_pendergast Member Posts: 2
    Try using the "Offset" tool.
