Creating a cylinder using API
hari_haran541hari_haran541 Member Posts: 7
Hello all,
I am trying to create a cylinder with API , but unfortunately i couldn't,
i can create a empty document to my account but, when i try to add a sketch in it it throws a error saying unsued filters ,
i tried removing filters from my code too but still facing the issue , Does someone already gone through this before..?
I would appreciate any solution or recommendation on This.
Thanks in advance.
  • hari_haran541hari_haran541 Member Posts: 7
    hi @Paul_J_Premakumar , Thanks for the input,
    I'm having trouble with the onshape-client for Python. I tried running the official documentation example to create a newSketch, but it fails with an Invalid input arguments... unused input data is {'filter': ...} error. The strange thing is, the official example for creating a simple cube works perfectl.
    Can you help me to overcome this ..?
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    @hari_haran541 : Can you share your code & the exact error message (line number etc..) you are getting. This will help in debugging the issue.
    Hi @Paul_J_Premakumar
    Thanks for getting back to me!
    Yes, of course. Here is Python script I am using to test for creating a newSketch, along with the full error message I'm receiving.
    The Python Code:
    The Python script authenticates correctly and successfully creates a new, empty document in my Onshape account. However, the script fails on the next step when it tries to add the newSketch feature.
    The Exact Error Message:
    The script successfully creates the document but fails on the add_part_studio_feature call with the following error:
    Failed to create sketch: Invalid input arguments input when making an instance of class BTMParameterQueryList148. Not all inputs were used. The unused input data is {'filter': {'btType': 'BTOrFilter-167', 'operand1': {'btType': 'BTOrFilter-167', 'operand1': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTGeometryFilter-130', 'geometryType': 'PLANE'}, 'operand2': {'btType': 'BTFlatSheetMetalFilter-3018', 'allows': 'MODEL_ONLY'}}, 'operand2': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTSMDefinitionEntityTypeFilter-1651', 'smDefinitionEntityType': 'FACE'}, 'operand2': {'btType': 'BTFlatSheetMetalFilter-3018', 'allows': 'MODEL_AND_FLATTENED'}}, 'operand2': {'btType': 'BTGeometryFilter-130', 'geometryType': 'PLANE'}}}, 'operand2': {'btType': 'BTBodyTypeFilter-112', 'bodyType': 'MATE_CONNECTOR'}}}
    It seems like the Python client library is incorrectly rejecting the filter parameter when creating a BTMParameterQueryList148 object. I tried creating a simple cube from the example it works perfectly but this failed.
    Thanks in advance for your help in debugging this!
    import json
    from onshape_client.client import Client
    # --- 1. CONFIGURATION ---
    DOC_NAME = "Onshape Official Docs Test"
    print(DOC_NAME)
    # --- 2. AUTHENTICATION ---
    try:
    client
    print("Onshape client already configured.")
    except NameError:
    print("Configuring Onshape client...")
    try:
    access = input("Paste your Onshape Access Key: ")
    secret = input("Paste your Onshape Secret Key: ")
    client = Client(configuration={"base_url": "https://cad.onshape.com",
    "access_key": access,
    "secret_key": secret})
    print(" Onshape client configured and ready to go!")
    except Exception as e:
    print(f" Authentication failed: {e}")
    exit(1)
    # --- 3. CREATE A NEW ONSHAPE DOCUMENT ---
    print("\\nCreating new Onshape document...")
    try:
    doc_params = {"name": DOC_NAME, "isPublic": True}
    doc = client.documents_api.create_document(bt_document_params=doc_params)
    document_id = doc.id
    workspace_id = doc.default_workspace.id
    element_id = client.documents_api.get_elements_in_document(did=document_id, wvm='w', wvmid=workspace_id)[0].id
    print("Document created successfully.")
    print(f"Failed to create document: {e}")
    if hasattr(e, 'body'): print(f"Error details: {e.body}")
    exit(1)
    # --- 4. HARDCODED DOCUMENTATION EXAMPLE ---
    print("\\nBuilding feature list based on official documentation...")
    # STEP 4A: Define the Sketch Feature (from docs)
    sketch_feature = {
    "bt_type": "BTMSketch-151",
    "feature_type": "newSketch",
    "name": "Docs Sketch",
    "parameters": [
    "bt_type": "BTMParameterQueryList-148",
    "parameter_id": "sketchPlane",
    "queries": [
    "bt_type": "BTMIndividualQuery-138",
    "query_string": "mateConnector(\"Front\")"
    "entities": [
    "bt_type": "BTMSketchCurve-4",
    "entity_id": "circle-entity",
    "geometry": {
    "bt_type": "BTCurveGeometryCircle-115",
    "radius": 0.025,
    "xcenter": 0.05,
    "ycenter": 0.05,
    "xdir": 1.0,
    "ydir": 0.0,
    "clockwise": False
    # STEP 4B: Add the Sketch and Get its featureId
    print("\\nAdding sketch feature...")
    sketch_payload = {"bt_type": "BTFeatureDefinitionCall-1406", "feature": sketch_feature}
    try:
    sketch_response = client.part_studios_api.add_part_studio_feature(
    did=document_id, wvm='w', wvmid=workspace_id, eid=element_id,
    bt_feature_definition_call_1406=sketch_payload)
    sketch_feature_id = sketch_response.feature.feature_id
    print(f"Sketch created successfully with featureId: {sketch_feature_id}")
    print(f" Failed to create sketch: {e}")
    exit(1)
    # STEP 4C: Define the Extrude Feature (from docs)
    extrude_feature = {
    "bt_type": "BTMFeature-134",
    "feature_type": "extrude",
    "name": "Docs Extrude",
    "parameters": [
    "bt_type": "BTMParameterEnum-145",
    "value": "SOLID",
    "enum_name": "ExtendedToolBodyType",
    "parameter_id": "bodyType"
    "value": "NEW",
    "enum_name": "NewBodyOperationType",
    "parameter_id": "operationType"
    "parameter_id": "entities",
    "queries": [
    "bt_type": "BTMIndividualSketchRegionQuery-140",
    "feature_id": sketch_feature_id
    "value": "BLIND",
    "enum_name": "BoundingType",
    "parameter_id": "endBound"
    "bt_type": "BTMParameterQuantity-147",
    "expression": "1 in",
    "parameter_id": "depth"
    print("\\nAdding extrude feature...")
    extrude_payload = {"bt_type": "BTFeatureDefinitionCall-1406", "feature": extrude_feature}
    try:
    bt_feature_definition_call_1406=extrude_payload)
    print(" Extrude added successfully!")
    print(f" Error adding extrude: {e}")
    exit(1)
    final_url = f"https://cad.onshape.com/documents/{document_id}/w/{workspace_id}/e/{element_id}"
    print("\n Process Complete!")
    print("View your new CAD model at:")
    print(final_url)
    @hari_haran541 : The python client is no longer being updated. It can be used for authentication, but beyond that the other calls are not guaranteed to work.As a workaround instead of calling the part_studios_api.add_part_studio_feature you can construct the required params and call the GET/POST methods using the generic client.api_client.request or one of the python library REST api calls.
