Origin Takes priority over other sketch points
Often I am trying to add a point that will be coincident with the origin but a different sketch that is between the origin and my current sketch will take the place and so instead the point is coincident with a random point and not the point on the origin. While this is not a problem immediately (because these points are usually coincident with the origin also) it becomes a problem if I delete a previous sketch and then I loose the coincident constraint. If there was an option to have the origin take priority of other points this could be avoided. I think this should be added as a selectable option in case some people don't want it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Select other…
