Query Variable - amazing but also mystifying
romeograhamromeograham Member, csevp Posts: 733 PRO
https://cad.onshape.com/documents/7b3e635f41bdf82cc9abf34c/w/04bc8a28f6bc3b39181a0c5c/e/0c0e4183640b1a6f3fc472c4
I have a situation where there could be an abritrary number of bodies - and I'd like to use Query Variables to help me apply, say, a chamfer to all of the edges on the top face of all bodies like this (Example 1 tab):
Or, apply fillets to all faces of an arbitrary number of bodies EXCEPT one face, like this (example 2 tab):
I would like to understand better how the stock Query Variable can be used to create the right selections for this, without using Adjacent (like is available on Query Variable+).
Does anyone have any suggestions / tricks? I find that I can't propagate a selection across bodies the way I'd like (for instance, the "#bottom_edges" QV in example 2 just selects all the bottom faces - which I don't want to do).
Thanks!
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 579 PRO
    Yeah these kinds of scenarios are part of the reason I jumped into developing QV+ because there are gonna be situations where stock QV just can't simulate an adjacency check with the available queries. Even just selecting the "top" faces of parts is something I don't think can be strictly defined by stock QV because it came with no directional checks.
  • romeograhamromeograham Member, csevp Posts: 733 PRO
    Yep - that's the problem I'm finding. I sure like your QV+ though!
  • S1monS1mon Member Posts: 3,854 PRO
    In case you haven't seen it, @EvanReese 's video about query variables is pretty helpful:
    https://www.youtube.com/watch?v=yGTHOXKgngE
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,499 PRO
    "loop chain connected" can sometimes be used instead of "adjacent" to exclude entities belonging to a face but I agree the stock QV is missing a few things…
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    QV+ is just invaluable in cases like these. also qCapEntities or qNonCapEntities would work very well for these examples.
  • EvanReeseEvanReese Member, Mentor Posts: 2,751 PRO
    My next video on the topic is going to cover cases where writing a few lines of code can solve it. These are great example cases!
    Awesome - can't wait. I did watch your Query Variable video a couple of times…and your use of Query Variable+ made it clear that some selections just can't be done with the stock Feature. As I try to incorporate new functionality to the team, I try (at first, anyway) to stick to stock tools, However, in this case, the work by @jelte_steur_info and @Derek_Van_Allen_BD to collaborate on a great "plus" feature was clearly needed!
    For this case, I think I'll just use the QV+ for now (since it does such a great job).
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Please add more examples here or submit support tickets so we can collect your ideas and incorporate them into the standard QV feature.
    @NeilCooke do you need application examples on parts where expanded queries would be useful or just general improvement requests? I could probably pull up some situations that spawned the development of QV+ to cover weird power selections that QV itself couldn't handle.
    Honestly the dream is 1:1 parity between everything in the standard query library and an option in QV+ that exposes that query to the user. It's such a benefit for feature development to be able to bash out a part studio with a stack of QVs and either not need to develop the feature in the first place or have a perfect roadmap for how to integrate the concept studio into a custom feature.
    @NeilCooke I can work up illustrations at some point, but I'm tight on time today. Some examples that come to mind are:
    • getting all faces parallel to a planar face (or plane or mate connector)
    • Getting faces that are the farthest in a given direction (for example, to query all of the top faces in Romeo's example)
    • qAdjacent has already proven very useful
    • Some way to q faces by draft angle. I don't currently know a good way for non-planar faces. I might start by trying an isocline on each face with the given angle and see if anything is produced, or just sampling a bunch of face normals, but both would be too much code and not accurate enough. A new internal function could possibly do this quickly.
    • Same as above but for edges. Imagine filleting the edges of drafted rib features and trying to get all of the "up" edges.
    • parallel edges (and similar) seem only to apply to the edges of the body with the seed edges. Sometimes you'd want to get them for all bodies and filter that down, for example after a pattern, but before a boolean.
    I know I've run into many others too. I'll keep thinking about it.
    I'll add a link to this IR:
    https://forum.onshape.com/discussion/28802/pre-defined-query-variables-like-for-sheet-metal-corners
    Part of what's tricky about a really great implementation of something like that would be to ignore edges that are tangent or close to it, or edges that are too close to outer corners (especially ones created by bend relief). I could describe in words what I'd like, and I suspect that an experienced sheet metal manufacturing expert would have some intuition/rules-of-thumb around this.
    edited December 2025
    @NeilCooke
    I was working on a custom feature the other day, and perplexity was advising me and hallucinated a function called qAffectedBy (i.s.o. qCreatedBy).
    This does come to mind as a great query to add wich we couldn't just use the current standard functions for.
    this might satisfy some of the cases @EvanReese just mentioned. Imagine a draft feature was already somewhere in the feature tree creating all these non-planar faces. a qAffected by could query all the faces that the draft was applied to? Maybe we should call it qApplied to though, because the faces/edges opposite the parting line will stretch/move as the draft is applied, and are therefore affected, but not implied.
    I have some examples in mind where I struggled with QV and even QV+, but that work was confidential.
    Also if drafts are applied on a curved extrude, the corner edges will become curved. So I've already been thinking about a tolerant parallel query function that allows non-straight edges. an evBox3d would be required and some algorithms/evaluations around the max xy vs z ratio and if the edge ends are on the furthest xy planes etc. But so far I've been able to get these done through qNonCapEntities, so I won't bother for now…
    @Rhett_Robinson just created another IR for Query Variables which I strongly support. While in the middle of any feature which supports Query Variables, one should be able to define a new QV that gets added to the feature list.
    Reposting it here for visibility:
