Is there a way to send multiple screen shots for feedback?
knuckledragger
OS Professional Posts: 9 ✭
I had an issue that would have been more clearly explained with a before and after screen shot was curious if there was a way to do that. Not sure if we could create multiple screen captures or hit a short record button to demonstrate the issue more clearly.
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@Knuckledragger You can. Once you do the first screenshot, you can use your own captures and attach them to the email you receive on the first one. I have looked at having a video record feature, which is supported but I have turned it off due to it requiring a plugin to work. It is not cross platform and makes the support experience different for each user. So far with well over 1000 tickets, the markup in addition to the description is more than enough in most cases. We will be making it very easy to share the document with support in the next week or so and that is the ultimate understanding of the issues.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.2
-John
