how to create a spring
in General
I am having trouble creating a spring and was wondering if anyone had a quick tutorial of how to make one.
Create a helix
Create a "curve point plane" based on the endpoint of the helix.
Sketch circle on the plane you created. Dimeter of circle would correlate to the wire diameter.
Sweep using the circle and the helix as the path.
Hide the body the helix is created from.
Let me know if you need a more in-depth tutorial and Ill make one tonight. Im sure others will chime in here as well.
https://cad.onshape.com/documents/cdae3a1f009f41e8b5dd7e9f/w/96a0850e944040979fd806e6/e/02d0b2e6e5f14132a6678321
Twitter: @onshapetricks & @babart1977
https://cad.onshape.com/documents/56b7166be4b08910278c4fdd/w/616b75f1743012bd0b525f0a/e/ffe1b502d6c2d4824ae15d1a
how do you make one in another shape when you already have the shape
There is a feature script named "Spring Creator 1" that does a decent job of making springs. Sorry, but I couldn't figure out how to post a link, maybe you can search it, or others can make a link.
