how to create a spring
brian_kohr
Member Posts: 1 ✭
in General
I am having trouble creating a spring and was wondering if anyone had a quick tutorial of how to make one.
Create a helix
Create a "curve point plane" based on the endpoint of the helix.
Sketch circle on the plane you created. Dimeter of circle would correlate to the wire diameter.
Sweep using the circle and the helix as the path.
Hide the body the helix is created from.
Let me know if you need a more in-depth tutorial and Ill make one tonight. Im sure others will chime in here as well.
https://cad.onshape.com/documents/cdae3a1f009f41e8b5dd7e9f/w/96a0850e944040979fd806e6/e/02d0b2e6e5f14132a6678321
https://cad.onshape.com/documents/56b7166be4b08910278c4fdd/w/616b75f1743012bd0b525f0a/e/ffe1b502d6c2d4824ae15d1a
