Export to STEP or SLDPRT, thread/hole characteristics wrong
josh_mutus
josh_mutus Member Posts: 2 EDU
When I exported a simple part to STEP or SLDPRT, the 2-56 threaded holes I had created in the part didn't make it when I imported the part into solidworks. They were identified by solidworks as M1.6 clearance holes.
I don't know if this works, but here's a link to the part:
https://cad.onshape.com/documents/d31c6618f560496ff0ae515c/w/4e5e9d511ca91e3db916c3e4/e/b4c5bf58b3e60d4b2b9b872d
    I exported and re-imported no problem? Is it that you want the part in inches? If so, just change the units of the file in SolidWorks.
  • josh_mutus
    Did you check the part in solidworks? I never tried re-importing, but when I examined the part in solidworks, all the threads were wrong...
    Hi, no i haven't checked the file, but a hole feature created in Onshape will only export as a cylindrical face and will not show as a "hole" in SolidWorks.
  • robert_morris
    robert_morris OS Professional, Developers Posts: 176 PRO
    Are you using the "Feature detection" in SolidWorks when you're importing the file? That is another part of the problem.
    When you create a threaded hole in Onshape, the diameter of the hole that you see in the part is the diameter of the tap drill. In your case, the tap drill for a #2-56 thread is a diameter of 0.7in (or 1.778mm). Since the actual thread information is not exported out, when you open the file in SolidWorks it is only seeing that 1.778mm diameter hole and not the threads. The size of a clearance hole for a M1.6 screw is usually 1.7 - 1.8mm, so when Solidworks runs it's feature detection function, it just assumes those holes are clearance holes for a M1.6 screw.
    Hope that helps to explain what you are seeing.
