How do you mate a sphere in a conical cavity?
paul_ragot
paul_ragot Member Posts: 18 ✭✭✭
Assembly consists of 1 conical cavity and 1 ball.
How do you mate them so that the ball is tangent inside the conical cavity?
See public document 'sphere in conical seat'
Thank you,
Paul
  • paul_ragot
    I must have answered myself with a blank answer, but this question is still unanswered.
  • paul_ragot
    Got a work-around:
    ball:create a mate connector on sphere centre
    seat: sketch circle of ball diameter tangent to cone-create mate connector on that circle centre
    mate the 2 connectors by fastener.
    however, this method only works for 1 ball diameter, not for any size.
  • AP
    AP Member Posts: 2 ✭
    I was able to get a ball to sit down in a cone by combining a tangent mate and slider mate, and the ball stays in place if its diameter changes.
  • paul_ragot
    I doing that on the example, it does not seem to work.
    Thanks.
  • paul_ragot
    Here is the hydrostatic bearing. I used connector mates to assemble both sphere and cup to the conical seat.
    If anybody can find another way using different types of mates, I'd like to know.
    Thanks.
  • paul_ragot
    Neil,
    Thanks. Still requires to create the extra mate connector on the sphere ( I guess we cannot avoid this), but better.
    NeilCooke Moderator, Onshape Employees Posts: 6,115 image
    Shouldn't need to, you could use the mate connector from the origin of the sphere or if you hover over the sphere one should appear.
  • paul_ragot
    Neil,
    Thanks, this is exactly what I wanted.
