type in depth of extrude after starting it
BouwyBouwy Member Posts: 16 ✭✭
What I do:
- I made a sketch
- Select the sketch
- click extrude (sketch is already selected as sketch to be extruded)
- want to adjust depth so click the 25 mm which is default and adjust it.
What I want:
- Have just made sketch selected
- click extrude
- Directly type for example 5 to change depth to 5 mm
That would increase work tempo.
Is that possible?
  • kevin_o_toole_1kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565 image
    Not right now, but you can press the tab key to jump to the next field in any feature dialog.
  • BouwyBouwy Member Posts: 16 ✭✭
    tab is a good tip, thanks!
  • jochen333jochen333 OS Professional Posts: 28 PRO
    Another idea: Control the extrude depth with the mouse wheel like in solidworks. Thats very handy for trying out / wangle something.
    You can already change any value with the mouse wheel - just make sure the value is highlighted first.
    edited June 2016
    - Not in sketches
    - Not on extruding
    Thats what i quickly tested. Mouse wheel controls zoom all the time.
    Or is it a Problem with the Logitech driver as often?
    Update:
    oh... cursor has to be in the field... thats it. Differs from solidworks ;-)
