Use opFillet for a sketch?
sören_svensson
sören_svensson Member Posts: 24 ✭✭
Hi,
I'm trying to use opFillet to fillet corners in a sketch but I'm only getting not really helpful errors like FILLET_FAIL_SMOOTH and FILLET_SELECT_EDGES.
Here's a current snippet (I've tried many variants)
    var outerSketch = newSketch(context, id + "outerSketch", {
            "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
    var outerPoints = [
        vector(rightX, (angleCenterX + rightX) * tan(upperAngle)),
        ur,
        ul,
        vector(leftX, (angleCenterX + leftX) * tan(upperAngle))
    for(var i = 0; i < size(outerPoints); i += 1)
        skLineSegment(outerSketch, "outer_line" ~ i,
        { "start" : outerPoints[i],
          "end" : outerPoints[(i + 1) % size(outerPoints)]
    // close sketch for outer race
    skSolve(outerSketch);
    var edges = [];
    edges = append(edges, qContainsPoint(qCreatedBy(id + "outer_line0", EntityType.EDGE), vector(rightX, definition.outer / 2, 0 * millimeter)));
    edges = append(edges, qContainsPoint(qCreatedBy(id + "outer_line1", EntityType.EDGE), vector(rightX, definition.outer / 2, 0 * millimeter)));
    debug(context, edges);
    opFillet(context, id + "fillet1", {
            "entities" : qUnion(edges),
            "radius" : 0.2 * millimeter
Every example I've found uses opFillet on bodies and not sketches but there's a fillet command in the sketch UI so I assume it should work.
  • sören_svensson
    Thanks for the answer!
  • Aaron_Hoover
    Aaron_Hoover Member Posts: 35 EDU
    Any chance the availability of opFillet in sketches has changed in the last couple years?
  • Jake_Rosenfeld
    @Aaron_Hoover
    The advice Ilya gives is still valid.  The "fillet" sketch tool actually alters the sketch code to push back the neighboring edges and insert an arc between them (with skArc).  Filleting after a thicken or extrude is a good option, as well as doing the calculations for the endpoint locations for skArc.  If you share your specific problem I may be able to give more specific advice.
  • Aaron_Hoover
    @Jake_Rosenfeld
    This is super helpful. I'm currently trying to create a FeatureScript to create a dovetail joint like in this "Halved Dovetail Corner" joint: https://cad.onshape.com/documents/f22179460c63ac8d20c705e1/w/411adc4bdfc59835797812ed/e/dd2666a629e40f017ce24997.
    In fact, there are many joints in the 50 digital joints collection that could make use of a "2D" fillet that gets extruded and Boolean'd (unions and subtractions) appropriately. So, I'm seeking a solution that makes this code as simple (and reusable) as possible.
    Do you have any examples of using the skArc to create fillets? It seems arduous to have to compute endpoint locations for straight segments to ensure tangency (for example).
    edited October 2018
    @Aaron_Hoover you don’t need to calculate them precisely, you can add constraints and skSolve. See the Spur Gear example. https://cad.onshape.com/documents/5742c8cde4b06c68b362d748/w/b493e0cb681bbf9497d9f4b3/e/01a666571e625f8b819fd75b
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,278 image
    I still think a solid fillet is likely to be easier...
