How to delete all dangling constraints?
james_mcpherson11762james_mcpherson11762 Member Posts: 26 ✭✭
I'm trying to build some parts libraries from other cad formats. Since Onshape can't import .dxf's I'm importing the 3D models, creating a new sketch, then using the "Use/Project" feature to project the 2D curves onto the sketch. This works (although it is tedious, 2D import into a sketch should exist), however when I then suppress the no-longer needed 3D model, each and every line has a dangling constraint referencing the original 3D model. I end up with hundreds of dangling constraints that I'm currently deleting one at a time... this hurts.
Is there a better way?
-Jim
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,087 PRO
    I don't know of a way to delete all dangling sketch relations inside OS.
    I do mess this dialog from SW and it's capabilities:
  • larry_haweslarry_hawes Member Posts: 478 PRO
    Has this been resolved in any meaningful manner? I'm sketching 'in context' and the use constraints, which I no longer need after the sketch has been created from another sketch are everywhere. The next sketch will be based upon this new sketch, or another context, but the use constraints will be in the way for the next step. Deleting them one by one is tedious to say the least.
    Would like to 'use' a previous sketch without the 'use' constraints. Any way to do so?
  • RyanAveryRyanAvery Member Posts: 93 EDU
    Me too.
    Is there a "Delete all constraints from selected entities"?
    Nevermind, I found a way to remove all constraints from a sketch. You just select the lines / objects you care about, do ctrl + c to copy, then right click a plane and click "paste sketch" and it will be pasted without any of the constraints.
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    edited February 2020
    RyanAvery  nice one. Unfortunatly you have to constrain the pasted elements again.
    Alternatively see:https://forum.onshape.com/discussion/comment/60364/#Comment_60364
