Extrude a mostly mirrored sketch doesn't work?
nocry3
nocry3 Member Posts: 30 ✭✭
Hello,
I have created a sketch for an aluminum system profile. 1/8 is drawn (meassured part) and the rest is mirrored. Unfortunately, I can not create extrusion from the sketch.
Only why is not clear to me.
    There must be a gap in your profile somewhere - if the area is shaded then it is good for extruding. A trick to find the gap is to draw a horizontal (or vertical) line through the sketch and drag it up and down to see which areas of the profile are shaded or not.
  • nocry3
    Great tip. But I can move the line arbitrarily and all partial amounts are represented as gray area. Only the whole profile not. Is this perhaps a bug?
    Not a bug - keep searching. You could also show constraints (in the sketch dialog) to see if there is a coincident constraint at each vertex.
  • viru
    @ralf, Can you share your document link with us so we can look into that issue.
  • nocry3
    I think I've encircled the error, but I do not understand it. It seems that the point in the rectangle is the problem. But why? All the other mirrored points are working?
  • nocry3
    edited January 2017
    Thanks for your help. My mistake but hard to find :-)
