Tiny Changes to Versions
bartbart Member Posts: 19
I saved a version but simply want to rename a couple of sketches in it. I can't seem to do that.
Instead I have to create a near-identical version then rename the old one "NOTHING" or something like that. It looks very messy. Is there a way to delete or edit versions without branching?
Many thanks,
Bart
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,147 PRO
    Maybe we need a way to hide those old unwanted versions from the tree, but still see them in an optional full veiw mode for transparency sakes, however, I think I would be fine if you could just delete the versions to clean up the tree. It is nice that we can now rename versions.
    Not sure if it helps but you can also make a version at any micro change.
  • bartbart Member Posts: 19
    I figured that was the answer. Many thanks!
