Few questions
joey_cjoey_c Member Posts: 1
I am new to CAD and onshape so I have a few questions
1- how can I manually set dimensions
2- how can I transform the shapen when I am done constructing it?
I am using the mobile version.
Thanks
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,031 PRO
    edited April 2017
    what do you mean by manually set dimensions
    dimensions are inherently manual.
    The dim command is located in the sketch tools menu, and is only accessible if you are currently editing a sketch
    It is good practice to draw your part in it's final position, rather than drawing it, then moving it later.
    But sometimes a transform is necessary... There is a "Transform" feature in the feature menu, you have many transform options to choose from
    including:
    by line (either select an edge of a part, or sketch a line and use it as the direction and distance you desire, perfect for keeping your transform's related)
    by distance XYZ
    Rotate
    Scale
    etc..
    If you want to transform your sketch lines while editing a sketch, select what you want to move, then press hold and drag one of the points, it will follow your finger in the XY direction.
    If you need to rotate a sketch, this can be tricky in the mobile version:
    first make sure you have no "vertical/horizontal" constraints that will limit your movement
    then draw a line that is fully defined / fixed, and use an angle dimension to control it
    Or fix one point and try to drag the other point around the fixed one
    Let me know if this helps
    Hi @joey_c ,
    In addition to what John is saying above, I think some of the videos over at https://www.onshape.com/videos/topic/tutorials may be helpful for you.  While we try to make learning Onshape as easy as possible, there is still a learning curve for getting into the CAD mindset.  Here are some good videos for learning the basics.
    Sketching: https://www.onshape.com/videos/sketching-basics-onshape
    Sketch Dimensioning: https://www.onshape.com/videos/dimensions-and-constraints
    After those you may want to watch Extrude, Revolve, and Sweep to turn a sketch into a 3-dimensional object.
