How can I create and ellipsoid?
luis_suarez
luis_suarez Member Posts: 4 ✭
edited April 2017 in Community Support
Hi, can someone please teach me how to create an ellipsoid in onshape?
a=25mm b=50mm and c=12.5mm
Thanks in advance, Ive been trying for hours
  • Jake_Rosenfeld
    Hi Luis!
    I did this for you but it was definitely a little complicated:
    https://cad.onshape.com/documents/532b38f642224df15d401cfa/w/941a58bc127033d70d4b7727/e/144129212c83fa16f0095271
    To accomplish it I sketched the cross section of the ellipsoid on all three default planes.  On two of the ellipses I bisected the sketch faces with matching lines down the center (this is so I could select half of the ellipse instead of the whole thing).  On the third ellipse I "split" the ellipse at the four points that intersect the major and minor axes.
    https://cad.onshape.com/help/Content/sketch-tools-split.htm
    I then lofted the first ellipse into the second ellipse using the split third ellipse as a guide curve.
    Written down in text, this is probably confusing.  Feel free to copy the document and edit the features to see how I did it.
  • john_mcclary
    https://cad.onshape.com/documents/c79dd64af6d9e510c22beb9f/w/cd3ff3163e4881619d96b993/e/9cfdc6ae30d7675951f88868
    @Jake_Rosenfeld  you beat me to it by 1 minute :) , but I don't think this is good enough yet...
    the lofts are comming to edges.. I see you have the same thing happening
  • Jake_Rosenfeld
    Hmmmmmm
    Yeah it appears this approach doesn't yield tangency over the 4 lofts:
    (If anyone is confused, this visualization is the 'Curvature visualization' option in the cube menu under the view cube)
    I'll chat with some people about making ellipsoids tomorrow.
    As a side note, it should be pretty easy to make a mathematically correct ellipsoid if any two of its axes are equal (should be just one simple rotation).
  • john_mcclary
    Best I could get was 3 overlapping parts, one from each axis, but they don't bool union because the intersecting surfaces are reaching infinity.
    and each part's poor approximation You would have to do this an infinite amount of times :( Defiantly no workaround I can muster up @luis_suarez.. sorry
  • john_mcclary
    nicely done @leon_poot
  • leon_poot
    leon_poot Member, Developers Posts: 87 ✭✭✭
    Cheers @john_mcclary.
    Apparently there is already a FeatureScript out there for non-uniform scaling (I completely missed that), but funnily enough it looks very much the same :smile:
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless
  • ilya_baran
    Leon's scaled sphere solution is correct -- I don't actually currently know of another way of constructing an ellipsoid (for three arbitrary radii) in Onshape.
    This is my nonuniform scale feature: https://cad.onshape.com/documents/ccbbbcd87f9c80f9650af745/v/d3f3849203d96becc718a958
  • Jake_Rosenfeld
    @leon_poot or @john_mcclary it seems like it would be pretty easy to make an 'Ellipsoid' custom feature that takes in center, x, y, and z lengths if either of you want to try your hand at it.
    If not I can try it out this weekend.
  • john_mcclary
    @Jake_Rosenfeld
    Yea, one of these days I'll sit down and learn FS
    but it looks like @leon_poot nailed it already :)
  • Jake_Rosenfeld
    Oops! I thought leon made a sphere and just wrote a non-uniform scale.  Turns out he wrote thing as one feature! Nice job @leon_poot !!
  • leon_poot
    Thanks @Jake_Rosenfeld, glad you like it.
  • luis_suarez
    Thanks guys this was a headache!
  • andrew_spokbee
    andrew_spokbee Member Posts: 11 ✭✭
    edited April 2022
    @leon_poot There appears to be a bug with the transform: when I choose a location other than the origin, it is not actually centered about it. E.g. a point 25mm from origin in Y direction. If Length X and Y are 25mm, it will be centered about 0,50,0. If Length X and Y are [50,25] mm, it will be centered about 0,37.5,0.
    In other words, it is being moved by an extra Length.X^2/Length.Y in the Y direction, up to a max of Length.Y
    S1mon Member Posts: 4,613 PRO
    This is a pretty old thread. The built-in transform tool has a non-uniform option now. Unless I'm missing something, it works as it should.
  • EvanReese
    I also made a Sphere primitive custom feature which has non-uniform options. Handy for slappin' some geometry out there quickly.
    @Evan_Reese
    Thanks for reminding me of that set of tools.
    BTW there's an issue with the Lattice example:
  • EvanReese
    Ooh, thanks! fixed it.
  • nicholas_radzykewycz
    nicholas_radzykewycz Member Posts: 30 PRO
    Okay, pardon if I have missed something obvious, but why would you not make an ellipse sketch and then just use the revolve command for this? That's what I would have done.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,930 PRO
    You would still have one axis that would be circular if you did it this way.
