How do I send a customer an animation?
terry_pipkin
Member Posts: 48 PRO
in General
What is the simplest way to let a customer see an animation?
Is there a way to imbed an animation on our company's website?.
john_mcclary
Member, Developers Posts: 4,051 PRO
Not directly from OnShape
But you can download a gif creator, or screen capture software. Make your video then embed that on your site
6
Here is a tip for everyone - when dragging the 'section' manipulator to define a section view, if you drag by the circular origin, this will invoke Mate Connection points and allow you to slice exactly through the centerlines of things. Try it! Once you do, you will always do it!
I'll have to try that out
The problem with all screen capture based animation is that you need to do it all over again if model is updated. This why I would strongly prefer Onshape taking a shot on this, world is filled with (de-)assembly instruction but lacking the software to create them efficiently.
