Complex surfaces
Agersens
Agersens Member Posts: 10 PRO
edited July 2017 in Community Support
I am modelling an injection moulded part with lots of draft and some reasonably complex surfaces, but nothing over the top.. Model was getting very slow so I got it to a stage where I had all the outside surfaces as a solid model and could shell the part.
I thought to speed up the process I would export a step model and import it back into a new part to finish off the rest of the part. Dumb solid effectively
When I import the STEP model back into Onshape I can no longer shell it, even though I could before I exported the same geometry.
Frustrating!!!!!
    Hi @Agersens if you must do that use Parasolid. How many features are in the part? You could also derive it into another Part Studio or link it into another Document.
  • brucebartlett
    Hi Ageresens, I am hoping what @NeilCooke suggested has helped solve the shelling problem.
    However, this shouldn't be an issue that you have to try and work around.  Have you logged it with the feedback tool?  I have experienced slow models in the past, sometimes it because they have got on a server in a different part of the world to where I am working.
