Draft direction and Neutral Plane
andreas_scholz
andreas_scholz Member Posts: 14 ✭
I wanted to create a part which is 22° orientated to the draft direction. When I select  a neutral plane the draft will be done normal to that plane? What about the case I want to select a neutral surface that is not planar?
  • john_mcclary
    When you select a face or plane to sketch on, it will always be normal to that face.
    You can only create a sketch on a flat face.
    If it is non-planar you will need to construct a plane first before creating your sketch.
    Please vote for parting line draft in the improvement request category (assuming a request exists)
  • andreas_scholz
    Hello to all,
    to make it a little bit more clear, please have a look at following simple example:
    https://cad.onshape.com/documents/b962676889c09f0d0bc6289d/w/51621f26a0d37db7347e9962/e/254f7c88e261e2fecd5ed4a1
    It is only one feature of a small plastic part I wanted to create last week. As You see the part is extruded between to parallel planes with an angle of 22° degrees to the top plane. The part should have a draft of 0.5° normal to the top plane (see direction arrow) as main draft direction (there are additional features that call for this direction!) with the upper plane as neutral plane. I am not able to draft the part in Onshape in that manner.
    What if the upper surface would not be planar and also should be the neutral surface for draft?
    I am primarily working for automotive industry where draft directions are often set, and adjacent surfaces or parting (neutral) elements for drafts are non planar.
    Thanks in advance for answering.
    Regards
    Andreas
  • andreas_scholz
    Hello again,
    I wrote my question in the category "IMPROVEMENT REQUESTS" because I am shure, that it is actually not possible to draft parts in Onshape as mentioned above.
    So my article would better be moved to the correct category.
    Regards
    Andreas
