allow setting angles equal
david_lang457
Member Posts: 104 ✭✭✭
I have run across a few cases where I want to set two angles equal to each other (similar to the way that you can set two line segments to equal lengths), but it appears there is currently no way to do this. Instead I need to set the angles to the same numerical value, which doesn't work when I want the angles to be generated based on other geometry.
https://cad.onshape.com/documents/c20e49034ae017371b469b8c/w/c7606b785669c4b91914cb9c/e/87cbf35dfbaf7dbb066ab9f2
Cheers
SledDriver
I have a tilted disk supported in the center with a ball joint that has a rim that will ride against a fixed rim. I need to set the angle of the edge of the disk based on the angle of tilt of the disk (which is generated based on the amount of vertical movement of a point of the disk during a full rotation)
one way to do this is to have the angle between the plane of the disk and the rim be equal to the angle between the plane of the disk and horizontal, but it's not a Z shape, both angles go in the same direction
https://forum.onshape.com/discussion/5951/add-variable-while-sketching#latest
Allowing you to build a variable reference on the fly which would make this process very easy.
- Bob
I offer up this simpler approach:
Draw it in the sketch, there's symmetry, there's a simple construction line & equal constraints or use a variable. For me, I want to open the sketch and know what's going on immediately. The fact that onshape declares a variable in the tree, to me it makes it totally usable & makes it good practice. It's not hidden and I don't have to try and figure it out, the angle assignment is obvious.
We all like numbers and equations. Solve the problem with a feature script, show your wife, get a hug, erase it and then draw it up.
To me the best modelers design for the next guy and using equations just makes it harder.
This is my opinion.
using variables can work in some cases, but only in cases where you know the angle ahead of time, if you want to do something like bisect an angle as you are manipulating the parts, it won't work
