How do I make A Vacuum Formed Tray like in Photo
jafri_hilmijafri_hilmi Member Posts: 3 EDU
215 top length
191 bottom length
2 thickness of all acrylic
16 height
7 top center ( the gap at the side
33.5mm small box
99 top width
76.5mm bottom
all dimension are in MM
Above are the Dimension
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,956 image
    Easy. Create a sketch using the dimensions you specify, then use the extrude command. After all fillets etc. added, use the shell command.
