Export Part With Color
wayne_sauder
Member, csevp Posts: 701 PRO
Is there a way to export a part in stl. format and it keeps the color you assign to it by editing the appearance? When I export a part that I made green, and then open that file in another program, it always opens in white. Am I doing something wrong?
Hi. The stl format is just a cloud of points (not even a solid) and does not allow for color. It's mostly used for things like 3D printing. Other more CAD-like formats will preserve colour, such as some flavors of step.
Cheers, Owen S.
HWM-Water Ltd5
Cheers, Owen S.
HWM-Water Ltd5 -
Ok, great and thanks for the help.0
No worries.
Owen S.
HWM-Water Ltd0 -
I am trying to use OnShape with my students for Augmented and Virtual Reality projects. Similarly having issues with color loss. I found the collada export (which is .dae) is working best so far with the Merge Cube viewer for Augmented Reality. However, I am still having issues with using it in CoSpaces. I really wish OnShape offered an OBJ export option that maintained texture.
kevin_white said:I am trying to use OnShape with my students for Augmented and Virtual Reality projects. Similarly having issues with color loss. I found the collada export (which is .dae) is working best so far with the Merge Cube viewer for Augmented Reality. However, I am still having issues with using it in CoSpaces. I really wish OnShape offered an OBJ export option that maintained texture.@kevin_whit, I think you would be interested in this prototype. It is an OnShape viewer for Hololens
had the same problem, tried different formats; found that "OBJ" kept the color when importing to "Anycubic slicer next"
