Dimensioning Problem
thomas_miglincithomas_miglinci Member Posts: 34 ✭✭✭
edited September 2017 in Drawings
Hello,
I encountered the following problem with a drawing: (see https://cad.onshape.com/documents/c4a43830ba766cc6ce0d27ed/w/09b56e4c8a752a62e2941390/e/fd9aab1d02deb8471bb68c57)
I have to pairs of holes which are on different sides of an object (in this case an L-profile) but are arranged symmetric to a common centerline. This is easy to construct in a Part Studio as these centerlines can be aligned on the corner and the distance for this line can be set from the baseline.
But when I want to make a drawing out of it:
  • I cannot direct draw a centerline between the holes. This can be faked by drawing two separate lines horizontal from both holes and attaching a centerline between those lines. And, this lines will not move if the underlying view is moved :-(
  • The distance of this faked centerline to the base of the object cannot be dimensioned at all !
Any help is appreciated - thanks
Thomas
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,953 image
    Hi Thomas, you are correct, this is not possible. You probably don't want to hear this, but you cannot physically measure an imaginary/inferred symmetry line, so best practice is to dimension all features from a hard edge.
  • thomas_miglincithomas_miglinci Member Posts: 34 ✭✭✭
    Hi Neil,
    yes, I do not like the answer, although I do understand your explanation.
    Thanks
    Thomas
    Morning Gents.
    I've not tried such things in drawings but in assemblies you can use dummy parts set to 100% transparency (or just hidden) to act as helper parts for locations / mate points etc.  Could you do something similar here?  If so that might retain the parametric nature of the dimensions.
    Owen S.
    HWM-Water Ltd
