Parasolid Translate
_Ðave__Ðave_ Member, Developers Posts: 712 ✭✭✭✭
Seeing that Onshape defaults to parasolid for translate and I've been lead to believe that step was more stable I thought that I should ask here if parasolid files are recommended within Onshape.
Thanks
Dave
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    Within Onshape just copy and paste.
    going from Onshape to other Parasolid based modellers (SolidWorks, SolidEdge, NX, VectorWorks etc) use Parasolid.
    going to non parasolid based modellers (Inventor, Creo, etc) used STEP.
    Kevin Thanks, I'm transferring to Solidworks for drawing and also to Mastercam for CNC machining. I presume that parasolid would be best for both then.
    Dave
    @Dave_Petit @Kevin Quigley Shouldn't usign the native file format to export into Solidworks be the best solution? Or is there some problem with the native SW file export?
    I'm asking because I don't have SW but I need to collaborate with SW users frequently.
    //rami
    The .x_t is a file containing the raw geometry with no history and I think some additional meta-data like part color.  As SolidWorks is a Parasolid based modeler, a .sldprt file is essentially the data from the .x_t with some additional data such as the parametric history.  As we have no way of mapping our features to those of SolidWorks, the file that is output is essentially the raw geometry in a .sldprt file.
    Jake Ramsley
    @JakeRamsley @3dcad. I'm using the latest version of Mastercam and although Mastercam is capable of opening Solidworks files for some reason it will not open a solidworks file created by Onshape.
    The solidworks file that we translate to is version 2011.  I am not sure why Mastercam can't open the file.  Doing a quick google search found other users running into an issue with 2011 solid part files, but they were back in 2011.
    Jake Ramsley
