Change units
dan_schwartzdan_schwartz Member Posts: 16 ✭✭
How to change units from Inch to mm for exist part?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    Please see the document menu top left next to the Onshape logo.
  • john_hyde_volpejohn_hyde_volpe Member Posts: 3 EDU
    Hey @NeilCooke, I understand how to change units using the top left menu option; however, some of my students are running into a problem. After they have finished a Learning Center tutorial design, they realize that they failed to use the proper units. When they go to the menu to implement the unit change (e.g., in ==> mm), the driven dimensions within their sketch still seem to be anchored by the previous unit abbreviations (i.e., in).  Is there a way to drive changes into previously dimensioned entities?
    No there is not. They would have to manually edit each dimension to change the units.
  • alnisalnis Member, Developers Posts: 452 EDU
    As a workaround, you could apply a Transform > Scale feature and for the amount type in/mm --- that's whateverUnitYouWant/currentUnit
