Performance issue - sketch level dragging - Onshape compatibility check is OK
in General
Hello,
i run Onshape on a dedicated graphics machine with dedicated Nvidia graphic processor. Firefox ist setup to use the graphic processor to 100%. Onshape compatibility check shows more than >200Mio triangles/s. My internet connection is tested with 90MBit/s.
When i need dragging at sketch level, the performance is very low. I could use the transform tool, but in some case dragging is much better...
Example:
Sketch linear pattern, dragging the vertical construction line to some else than 90°.
The refresh rate goes down to less than 1 picture every 3-5 seconds. Also dragging of a sketch item is very slow.
Can anyone imagine what's the problem? Is it slow performance of Onshape Servers or Internet connection?
I am located in Munich/Germany/Europe.
wolfgam
Example:
wolfgam
- If this is document specific, Can you share a link to the document you are working on , this could diagnose the issue.
See my public test document with several linear sketch patterns:
https://cad.onshape.com/documents/91d1d6623c185e08558d3fef/w/9ffcaf7ff5899c3e767cad57/e/5543154cdb71daf75c1508e7
(Folder patterns, sheet sketch patterns)
