<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Why is face pattern failing?
bruce_williams
Member, Developers Posts: 842 EDU
Circular Feature pattern works but Face pattern of 3 rib faces returns 'pattern could not be created on the same part'. Linear Face pattern works. I left the failing feature in the document here.
www.accuratepattern.com
Yes, @ethan_1 is correct, feature pattern is the correct usage here.
5 -
Face pattern only works if each instance shares the same faces - in your case, the sides of the block are different.Senior Director, Technical Services, EMEA1
Alternatively, you can choose to not merge your rib, use a part pattern, and then join the bodies with a boolean. OS seems to lead you away from using feature patterns since it's more costly to rebuild.5
Not sure why its failing, but under the drop down where it says face pattern if you change that to a feature pattern and select Rib 1 it works.1
5 -
@ethan_1 & @john_mceleney
Thank you for your responses. Feature certainly works.
John or anyone - you seem more knowledgeable about the 'correct use' What is the criteria for using Face vs Feature besides what works..
? Seems to me the geometry should work either way and I remember Face pattern is less 'costly' than Feature. And again, Linear Face pattern works with the three rib faces...
www.accuratepattern.com0 -
