I Love the Restore Sketch Function
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Just spent 10 minutes on a sketch then accidentally canceled it, my heart was broken because I thought I had lost my work but was overjoyed when I could restore it with the little popup at the top.  Thanks Onshape team for these little life saving features.
  • StephenGStephenG Member Posts: 384 ✭✭✭
    Just to let you know you only have 15 seconds in which to "Restore" the "Canceled" sketch. After 15 seconds the sketch is gone forever.
    There used to be a count down timer next to the popup, but it is no longer there.
    Comment: The OK-Accept green check button should not be that close to the red X-Cancel button. It is too easy to "accidentally" cancel a sketch. Questionable UI design.
