How to weld two rectangular plate in onshape
Welding option
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    That depends on how you like to show weldments in your design:
    1) Weldments as sub assemblies (recommended)
       1a - Draw each part in the same, or separate part studio
       1b - Create a new Assembly
       1c - Insert your parts into the assembly and add mates as required
       1d - Use BOM as a stock list for your drawings
    2) Weldments as monolithic solids within the SAME part studio
      2a - Draw each part in the same part studio
      2b - Use Boolean "Union" option to combine parts into a single part
      2c - Manually create a stock list in drawings
    3) Weldments as monolithic solids from SEPARATE part studios (not recommended)
      3a - Draw each part in a separate part studio
      3b - Create a new part studio, or choose one from the existing parts
      3c - Use Derived Part to add the additional pieces into your current part studio
      3d - Use transform / patterns as required to position your parts
      3e - Use Boolean "Union" option to combine parts into a single part
      3f - Manually create a stock list in drawings
    4) Weldments as monolithic solids in same parts studio naturally
     4a - Draw your first part in a part studio
     4b - Draw your second part in position and select the ADD option on any extrude/pattern command
     4c - Manually create a stock list in drawings
  • atul_rajput419
    atul_rajput419 Member Posts: 4 EDU
    No it is not working i want to create weld joint between face of two rectangular plates
  • Paul_J_Premakumar
    Paul_J_Premakumar Member, Onshape Employees Posts: 236 image
    Can you share a link to your document? Also if this : https://forum.onshape.com/discussion/8966/how-to-use-welding-feature-in-onshape#latest , is the same question as this one, you may want to delete it.
  • john_mcclary
    I didn't know we can delete a post, where is that option?
