how to use welding feature in onshape
atul_rajput419atul_rajput419 Member Posts: 4 EDU
weldment
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    edited April 2018
    Hi @atul_rajput419, Onshape doesn't have weldments. Can you provide more information about what you are trying to do? Folks on the forum, will be happy to help, if there is sufficient detail in the question.
  • atul_rajput419atul_rajput419 Member Posts: 4 EDU
    I want to weld two rectangular plates along its length. Specially V butt joint
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    There is no 3D weld feature in Onshape. You should add your weld details as an annotation in the detail drawing.
