Prevent Part Studio From Rebuilding with certain configurations
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
I would like to be able to stop the Part Studio from rebuilding when certain configurations are selected.
IR for AS/NZS 1100
    @mbartlett21 I would like to better understand this.  Why are you wanting this?  Is it mainly due to the regen time or having to wait?  I am not sure we want to have controls like that as they are more overhead that seems we should just try to do the right thing and know when a regen is necessary.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Do you mean you want to disallow certain combinations of configuration parameters?  Or do you actually want the part studio to fail to regenerate?  You could attain the latter behavior by putting a custom feature at the end that checks the combination and just deletes everything in some cases.
    @ilya_baran
    Yes to your first statement.
    I can't make the second behaviour work, because I can't use delete part on SM parts
    IR for AS/NZS 1100
    We plan to do something for restricting certain combinations upfront, but it's not near-term.
    For deleting sheet metal parts, you have to "finish" them first in FS.  Here's an example that does this -- it deletes everything if the configuration is wood and anything over 20 inches.  Note that I used the new configuration FS id editing functionality to make the internal ids match the names for the configuration inputs: https://cad.onshape.com/documents/ebba8f836a72a78d77c9174e/w/b13c08d970512acdbdb10f26/e/b83e350f778196726eed5eac
