Patterns in Sketches? Patterning of Features?
JregulinskiJregulinski Member Posts: 1 PRO
Hi folks,
I like to bolt things to other things, and thus I put a lot of holes in the part I design.
There seems to be no way to pattern with in a drawing. Is this a feature that will be added at some point or is there a desire not to have patterning in sketches?
In the interim I should be able to pattern the hole I make in a part, however this does not appear to work. It seems like I can only pattern parts, not a feature applied to a part, Is this correct? If so is feature patterning in the pipeline?
Thank you all
  • ingo_knochingo_knoch Member Posts: 12 ✭✭
    Hi, I see this in the same way. For me it would more important to pattern features instead of sketches.
    Bye Ingo
    Best regards
    Ingo Knoch /Lino GmbH Germany.
    This is marked for an improvement. If you have improvement requests, please send them in via the Feedback page in the ? menu inside of Onshape.
This discussion has been closed.
