Rip a pipe for flat pattern
How do you rip a pipe so it will give you the flat pattern?
Thanks,
Larry N
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    edited April 2018
    https://cad.onshape.com/documents/28050bca2b1ddeb0acbab720/w/72369ffa7faabbf84de28ab1/e/83132e95ca640c16597dc091
    See example above
    What you do is draw your tube with a split circle
    extrude a surface using the split circle
    then use the sheet-metal tool to thicken that surface
  • bryan_lagrange
    bryan_lagrange Posts: 1,036 ✭✭✭✭✭
    I find putting the k factor to 1 gives you a good flat pattern to work with.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • kevin_mason558
    kevin_mason558 Posts: 70 PRO
    @brucebartlett
    when I tried split with my pipe (made using frame tool) it splits straight through into two parts
    is there a way of only splitting once?
    Problem would be joining the two patterns on one face, if it's split in two
    I have a pipe that is mitred then notch so there's a different shape on the two halves when it's flattened
  • eric_pesty
    eric_pesty Posts: 2,854 PRO
    @brucebartlett
    The best way to do this is probably do a thin cut (make it less than the "minimum gap" in the sheet metal feature):
    Note that I could even do a sweep instead of an extrude to split both frame members in one go in this case
