Mate connectors in Part Studio stay behind when I transform their owner part
chris_8
PRO
Am I missing a way to bind the part to the mate connector?
thanks,
Chris
Example:
https://cad.onshape.com/documents/6b714e18e39e7a82c583e9db/w/1b919740fcf6075f60128924/e/3e3023a32957b2f261920b77
thanks,
Chris
Example:
Mate connectors don't bind to the part in the part studio but if you select the mate connector in the move feature it will move as well.6
No, it is not possible to move a sketch with the move feature.
The only way to move a sketch would be by rolling before the sketch feature in the tree and move the sketch plane before the creation of the sketch. Off course this will also depend on how the sketch constraints are referenced to the origin or other geometry.5 -
That's a bug, they should be able to be hidden. I'd report it with you feedback tool "?" top right.chris_8 said:Now that I've cleaned up my Part Studio by including the mate connectors in the transform commands, those mate connectors can no longer be hidden. Mate connectors that remained static can be hidden, but the ones that relocated are permanently visible it seems.5 -
Ok, so i had a go at this, and it is a perfect storm.
Normally, a user would have at least one of the following;
1) Access to the part feature history - this would enable you to put the mate connector at the center of the bottom face before cutting away the cylindrical opening.
2) Two vertical faces that would allow you to use the 'between entities' option in the mate connector dialog.
3) The ability to derive in a mate connector attached to a part
In the absence of these, a sketch is the way to go.
Philip Thomas - Onshape1 -
I didn't even remotely consider that, but it works!owen_sparks said:I believe that if you hide the transform feature in your feature tree then that will hide the mate connector.
Owen S.0 -
@chris_8 - YES, you are correct.
'Between' enables you to position and orient a Mate Connector and then say 'but half way between this face and this one'
(this is straight from the help - https://cad.onshape.com/help/Content/mateconnector.htm)
Thanks Bruce. That works. I realized there is an extra layer in my issue. My example blocks were designed without all the features of the part studio that had sparked my question. There was a sketch involved in my design, and the mate connector was attached to a midpoint on the sketch. I had tried clicking on the sketch to have it moved as well, but it wouldn't get selected. I didn't ever click on the mate connector itself until you mentioned it, I think I had tunnel vision focusing on that sketch (see below).brucebartlett said:Mate connectors don't bind to the part in the part studio but if you select the mate connector in the move feature it will move as well.
Now I know how to move the mate connector. Is it possible to move the sketch as well?
https://cad.onshape.com/documents/6b714e18e39e7a82c583e9db/w/1b919740fcf6075f60128924/e/7fe629eee1ac35df8f394160
Now that I've cleaned up my Part Studio by including the mate connectors in the transform commands, those mate connectors can no longer be hidden. Mate connectors that remained static can be hidden, but the ones that relocated are permanently visible it seems.0
Done. Have a great weekbrucebartlett said:That's a bug, they should be able to be hidden. I'd report it with you feedback tool "?" top right.0 -
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3 -
Owen S.0 -
1) This was a Mcmaster part import, so you're right: there was no access to a feature tree.philip_thomas said:Ok, so i had a go at this, and it is a perfect storm.
2) Honestly I didn't understand "Between entities" then. I thought of entity as a body, but it can indicate 2 different faces from the same body? That's good to know!0 -
I've been through that help before and I skirted around it because it didn't seem to work as I expected. I didn't have a need for "between entities" at the time so I shrugged and moved on.philip_thomas said:@chris_8 - YES, you are correct.
After working with it this evening I realize my issue was misinterpreting the "between entity" box. I expected to be able to specify 2 things in the "origin entity" box, and then expected the mate connector to appear in between the two. But I could only choose 1 entity. I saw the "between entity" box and thought I don't need to click there because I already chose Between entities.
If entity 1 is an origin, I'd expect entity 2 to be a terminal or something. Between is what I expect to happen between entity 1 and entity 2. How does entity 2 get defined as between entity?
I get easily tripped up be wording in OS sometimes. I went off on a rant about 'derived' years ago once I finally figured out what it's really for. I'd been searching through help for Copy part, or Insert Copied Part, or Duplicate Part to no avail. It Derived me crazy
Now I know. Thanks1 -
I agree the between entities feature input dialogue is slightly counter-intuitive. I was expecting to pick two points not a point an a face, however once understood I like it a lot.In the example It's especially useful if you have some tolerance (slop from side to side) in the pin, so you don't want to mate a surface on one end of the pin to one side of the bracket.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@philip_thomasphilip_thomas said:@chris_8 - YES, you are correct.
I'd like to select a point as the between entity. Is there any way to do this?0 -
@mbartlett21 - you mean like this?
https://cad.onshape.com/documents/dfaa5483ff7746bf49404630/w/593df3a65236749750bc8614/e/a2695c0099131730ccd2801c
Philip Thomas - Onshape0 -
Has anyone filed an improvement request on any of these issues? I think mate connectors should move with the derived part in part studios when you transform the derived part. I see no reason for them to stay in the original location. And you should be able to hide them.0
@PMS - you are welcome to submit any enhancement request (and as a pro user we take them very seriously), but just to be clear, you can move the MC with the part(s) being transformed (just include the connector in the selection of things to move) - it's second nature to me now, but i just wanted to make sure you knew this - works great!
