Is there an Onshape app or function that calculates the total area of a single part?
randmmanufacturing
Member Posts: 1 PRO
The area of a 3D part determines powder coating costs. These parts are all steel plate rectangles with rectangular cutouts and round holes of various sizes. A generalized app would avoid creating different area formuas for each part, and could accommodate new parts of greater complexity.
Many other Onshape users must require area calculations. What soultions are available in the Onshape Universe
Frank Roberts
R&M Manufacturing
randmmanufacturing@gmail.com
Registered Owner
Built into Onshape - Select part and use the 'Mass Properties' feature. You may also select faces to get area of just those.
Another sweet tool is the Feature Script - 'Calculate Bounds' for getting Extents of one or more parts or surfaces.
www.accuratepattern.com5 -
You could also create a custom property for your company to store this info after calculating, this could be caledl Coating Area and store the results for each part here manually.
It also may be possible to write a feature where you select the face to be coated and it writes that area to the custom properties of a selected part. This would then be a feature that lived at the end of your feature tree for this purpose only similar to what can be done with the part number feature.0
