Quick design contest
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
I don't usually design stuff like this but had to model existing part. Thought it would be 12 minutes to model but found myself struggling with the approach to model it easily so that it could be also produced according to model (I only needed something that looks similar).
Wanna give it a try?
Please reply with a link to public model and screenshot if you like.
It's missing some R but just use whatever that looks the same.
Obviously the word contest means that you should model with as few features as possible and the great reward is .. amm.. errr.. winning the contest!!
I'm sure this will end up with FeatureScript that makes any flange according to parameters with a single feature
//rami
https://cad.onshape.com/documents/0fbc3a8cc9f942743799c1be/w/22f927c6ff0cec65bf8dac6e/e/32061d1dee18f3425edf2cdb
https://cad.onshape.com/documents/c6a4e9f849a3690b3c78791c/w/242d57385e1fc23c93377a69/e/32df11fbcc78e35e6690cbb5
Partner de PTC - Onshape Averigua a quién conocemos en común
HWM-Water Ltd
HWM-Water Ltd
Note that there is a difference between a 'version' and a 'revision'. A 'revision' is a feature of our new release management system (available for professional users), while a 'version' is an immutable marker of progress in a document (available for all users). For your derive, you needed @NeilCooke's document to have a 'version', not a 'revision' (which, I think, is why he was slightly confused).
The distinction is documented here:
https://cad.onshape.com/help/Content/release_management.htm
and
https://cad.onshape.com/help/Content/versionmanager.htm
HWM-Water Ltd
Here's images of real part - as there is no data on exact dimensions I call it a draw. Neil's model was smoothest but Eduardo had fewest features.
Can't say if Eduardo had the 10mm thickness correct..
I totally forgot about Draft, thanks for the reminder Neil.
This part is good example of something that needs you to think 'cad' rather than think how it's made in real world when modeling.
My original model was 19 features, but with a little tuning on Neil's got it on 17.
If you are beginner or don't usually model this kind of stuff - give it a try.
Add this leg to your flange. Question: What is the overall height from floor to top of flange?
But with a small changes now it is 10 mm and keeps the same number of features.
12 !!!!
(and yes, the 10mm was a head scratcher
Now i am going to walk to the other end of the building where @NeilCooke is sitting and gloat
(then he will do it in 11
https://cad.onshape.com/documents/2290a8526be57ab9dc5f3a06/w/776e47bb5cc1e0c551b059c2/e/e97cfa2096de3a835f92d357
Based in your own model
11 !!!!
Wait there are 15 indeed with the default geometry... the same that in my first attempt
https://cad.onshape.com/documents/cda06c69636d0bd302383f35/w/385cb9cfa9134feea12a85f7/e/43459a16407d93f80dfb33b8
https://cad.onshape.com/documents/cda06c69636d0bd302383f35/w/385cb9cfa9134feea12a85f7/e/209d3deea9088ff62c0ee41b
Why the split face??
You have also given me a clue to take out one more!
I have done a variable fillet to get only 1 fillet feature. Actually I don't like it but...
It's 9!!
https://cad.onshape.com/documents/cda06c69636d0bd302383f35/w/a5051e0195ff85b21f4a10ff/e/209d3deea9088ff62c0ee41b
https://cad.onshape.com/documents/cda06c69636d0bd302383f35/w/0b8355a9652dc82b891d018d/e/209d3deea9088ff62c0ee41b
A checker may say that your part is the wrong size! Just saying
