Revolve about an axis
phil_joycephil_joyce Member Posts: 13 PRO
Does anyone else agree with me on this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Onshape also lets you select a circular face or edge to define the axis.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    I think it's awesome you dont need to explicitly define an axis everytime. Call it what you want. It works well and is easy. What else do you want?
  • phil_joycephil_joyce Member Posts: 13 PRO
    So I can use either the axis or a defined circular locus?
    Call me a pedant John, but terminology is important to avoid misunderstanding. If the Revolve command can accept either an axis or a locus as input, then there is no problem at all with the words 'Revolve axis'. I must be doing something else wrong when I cannot get the axis to generate my required revolve (in another document - not the one shown).
    Hmm, i could have swore you can use a proper axis to revolve. Are you sure the axis wasn't off center or not vertical by some .000001° or something?
    Linear edges should be fine to define an axis:
    Specifically, selections which take axes can extract an axis from a linear edge, a circular (or arc) edge, or a cylindrical face:
    ^ The curious may want to take a look at query.fs:
    https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/9fde5dffaf8d4e4c99aaa22c
