CNC Export Vector Breakup
I exported a few sketches to .DWG and .DXF for CNC routing.
When I imported them into PartWorks it had broken each sketch into separate vectors, which meant that I had to manually fix them in CorelDraw.
Does anyone know why this might have happened and how to make them one continuous vector? Here is an example of one of the sketches. This one was broken up into eight vectors: four edges and four curved corners.
https://cad.onshape.com/documents/89d21b4e63624f45b1d3fc3e/w/10e564195f6449daaef1bffe/e/97f9c4d1a896448998a96dfd
Many thanks.
Many thanks.
Vectors are inherently discrete, and it seems to me that what you are asking for could only be achieved by approximating a chain of geometrically primitive geometry (eg lines and arcs) by a single spline. There is currently no "fit spline" functionality in Onshape, so this substitution would have to be done in another package.
At least, that's how I see it.5
I very happy with the current .dxf export for faces and sketches, I am now going straight out of Onshape and into trumpf trutops to program for laser cutting.
Twitter: @onshapetricks & @babart1977
Not sure if closed polylines is what you require. You would have to find out from Shopbot.
