Lookup table partial visibility
murat_bakkal
Member Posts: 7 PRO
Hello.
Is there a way to show one part of a lookup table and show the other part of it separately? For example, if there are 3 levels of information in the lookup table, I would like to show the first two selections in the beginning of the UI and show the remaining selections depending on a boolean type. Is this possible?
1
No, this is not possible. Please create an improvement request.Senior Director, Technical Services, EMEA5
If the next-to-last option does not require the last option, then that can be set in the lookup table and the UI will update accordingly. If the last option is optional and not dependent on the previous one, the only thing you can do is have a value something like "Not set" so that the user does not have to define the last option.Senior Director, Technical Services, EMEA5
@NeilCooke thank you for your answer. I would like the last level of my look-up table to be optional. Do you have any suggestions on how I can approach this problem? Are there any examples to this anywhere?
@NeilCooke, thank you for your replies. For anyone that might need an idea for similar problems, it looks like this:
The "Use recommended length" key is an internal condition in the program that does something different. This selection is set as default.0
