If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
loft using path not working anymore?
 Lyle_Walsh
                    Member Posts: 46 ✭
Lyle_Walsh
                    Member Posts: 46 ✭
                                  in General
                    https://cad.onshape.com/documents/5a55a128a3c604c74f83e3fa/w/5fb8568b79431b1f2646ebcc/e/8ee154e52529bb67c270d06d
using loft along a composite curve where the 2 faces to connect are in different planes was working and now it doesnt work, ie document will no longer generate giving me errors I cant understand
"a guide has no adjacent faces to match tangent or curvature to"
Try using Sweep, instead of Loft
IR for AS/NZS 1100
HWM-Water Ltd
projektowanieproduktow.wordpress.com
HWM-Water Ltd
Here is the last state when the loft worked
compare Shows slight geometry modification of Sketch 8 causing self-intersection in Loft 2. I suspect it is due to the guide no longer passing through a vertex of Sketch 8.
I suggest using pierce constraint in sketch to tie two curves together.
