hole diameter extrusion error
bill_danielsbill_daniels Member Posts: 279 ✭✭✭
https://cad.onshape.com/documents/410b96f2236fdf1c3c3f53ec/w/382ea78034518f2c0ddf54ed/e/e1b0e65fb636b859e58fc2fd
This is a simple part which is supposed to have a 2.362" diameter hole in the center.  The sketch says 2.362 but the extrusion made from that sketch results in a 2.283" hole
  • bill_danielsbill_daniels Member Posts: 279 ✭✭✭
    Note that I changed approach and used the hole feature instead of an extruded circle which resulted in the desired 2.362 hole.
    @bill_daniels
    Glad you found a fix!  If you would like us or the community to take a look at what was going on with the messed up extrusion, you can go back in the history of your document and "Create a version" at a point in history that had the messed up extrusion.  Post the link to that version here and we can take a look!
