Duplicating or Splitting a Part
bart_harris
bart_harris Member Posts: 29 ✭
I need two hinge bars. I have drawn one. How should I make the second? Do I have to make it in a new part studio or can I duplicate it or split it in the same part studio? Here is an example:
https://cad.onshape.com/documents/6851b01973b14124bcd6224a/w/44ab6ee4efae4df08c015b92/e/853e76049eec44a1a4d5e725
Many thanks,
Bart
  • bart_harris
    Many thanks @lougallo !
  • andrew_troup
    For a duplication where you want lots of copies, you might consider linear pattern
  • bart_harris
    I feel like I half tried that. Can you do that with extrusions or just sketches?
  • andrew_troup
    edited May 2015
    There are two different linear pattern tools: one works inside sketches ...
    Whereas the other works to duplicate whole parts, or faces on parts.
    ("Faces" is a checkbox option within part-level "linear pattern")
