Release Management Customization
adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 304 PRO
edited July 2018 in Product Feedback
In order to align Workflow with existing Processes at a company Release Management. I know this has been mentioned before, just wanted to formalize it as an IR and provide some wish-list features:
-Customize Workflow
    -Add States and Transitions
    -Add Workflows and jump handlers
    -Rename State/Status
    -Allow/force scheme for Version Numbers
-Customize Revision Scheme
   -Allow multi-level schemes  ie. 002.A
   -Dynamically transition and increment schemes levels
   -Set rules for events
-Customize Part Number Scheme
   -Allow Multiple Schemes
   -Allow Multi-section schemes (Currently only two,
   -  XXXX-YY-1234
   -Formal Selection of Separator between sections (Dash, Comma, Space, Underscore, period, etc...)
   -Allow Sections to be linked to a Property in the component
-Release Candidate Dialog
    -Automatically assigned Approver based on criteria (Project, Team, Label...)
    -Automatically Assign Released Name based on rules or scheme (think Change Order)
-Other
   -Ability to Lock/Sync between Model (Part or Assembly) and corresponding Drawing
       -This ensures the sync of Revision counter
CAD Engineering Manager
    edited August 2018
    @adrian_velazquez much of the is on our radar and the first few iterations are about building the foundation and release flow so it can be built up to support workflows, more revision types, triggers, part numbers etc.  Much more to come in future releases.  As much of these are a wish list, adding it to our improvement area is not really going to be helpful for voting as we typically tie these to single features.  I brought it here for dialog.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 304 PRO
    Thanks for the update Lou, I figured that was why. My post started as a single request for custom workflows but turned into this as I started typing.
    As I mentioned, I've heard that most of this were in the works, but not sure how one could do something to help them get prioritized.
    Any possibility us curious critters could get road-map visibility? Similar to what Office 365 does would be nice:
    https://products.office.com/en-us/business/office-365-roadmap?filters=
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    Came here to request major and minor releases. I think that's what's meant here by "Allow multi-level schemes" and "Dynamically transition and increment schemes levels"
    I made a custom scheme that's formatted "0.00" so that anything after the decimal is a minor release, like a 3D print, and anything before it is a major release, like an official design review or placing a PO for a part. As it stands now, if I release my top-level assembly in a major release, then I'll have to manually go to each part and increment the number to the next major release number (i.e. 1.00 instead of 0.01, which would come up automatically). It would be awesome to have a way to tell Onshape that I want this whole release to be "major" or "minor".
    Anybody else have a good system figured out? I'm definitely still learning a lot and working on mine.
  • Stefan_DMSStefan_DMS Member Posts: 48 PRO
    I can't remember what post this was on but there was a discussion about using a letter-number system. So like A01, A02, A03... B01, B02, B03... C01 etc.
    Every major release you would need to type in the first B01, C01... or you can do it the other way around to 001A, 001B, 001C....
