How can I wrap a half sphere and cut cylinder patterns in it?
martyn_kempmartyn_kemp Member Posts: 5
I want to create a shape like this > https://www.thingiverse.com/thing:5827554
I don't know how to achieve this in onshape.
Thanks
  • john_lopez363john_lopez363 Member Posts: 125 ✭✭✭
    Combination of:
    - Attractor Pattern Feature Scrip (courtesy of Evan_Reese)
    - a couple of regular Circular Patterns
    - and a few other standard model development Features
  • martyn_kempmartyn_kemp Member Posts: 5
    edited February 2024
    Thank you so much that is perfect, have you got a link to the example you showed @john_lopez363
    I have tried and failed, it seems to rotate from the edge instead of where the centre hole is, perhaps I should have used the front plane instead of top.
    Changing the plane did not help either.
