How to move New Custom Property from "Pending" to "Active"
S_RegulaS_Regula Member Posts: 95 PRO
I'm trying to create several new custom properties. The first one I created is for an assembly and shows the status as "Pending", which I assume is why I cannot see the property in assembly properties. How do I move a new custom property from "Pending" to "Active" so that it is available to all users? TIA!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    edited February 2024 Answer ✓
    Just go back to the custom property and change the publish state to active, but remember to press the "save changes" button at the bottom of the page.
  • S_RegulaS_Regula Member Posts: 95 PRO
    Thanks. After I posted this I realized I did not change the publish state. Lesson learned!
